I have read about pads, but what about cymbals?
I am going A2E with Roland triggers and Cymbals
Specifically
Roland 12" CY-12C-T and Roland 16" CY-16R-T
One 16" I will be using as a three zone, so It will take two inputs. But the others just as crashes, splashes with no bell sound (which I hardly play even on acoustic). So I am wondering if I can plug, say, 2 Roland 12" CY-12C-T to the same input using a splitter
Thanks!
Can you plug TWO Roland CY16 cymbals into ONE input in dual mono?
- AndreaZanini
- Contact:
Re: Can you plug TWO Roland CY16 cymbals into ONE input in dual mono?
Yes, you can, but you will not be able to choke them.
- AndreaZanini
- Contact:
