So I'm a little sick of trying to get my homemade electronic snare to work. I don't have much time in my day to play and spending it trying to tweak a drum is not worth my time or effort.
I built a centre bar and mounted a side trigger to the centre and I keep having issues.
I'm at the point where I just want something plug and play. With snare being the most important drum I want something that just works.
I don't need positional sensing as I would rather have good triggering.
I'm looking at either
Roland PDA120LS
Alesis Strike Pro Snare Drum
A prewired trigger setup
I'm open to any suggestions you might have!
Thanks!
