eDRUMin4 - can two be used in tandem?
the_massive
Post by the_massive »
I really wanted to get the eDRUMin10, but it looks like that's a ways off. I just bought two of the 4's, but want to make sure I can control them both at the same time before I plunk down for a set of triggers.
Thanks!
Re: eDRUMin4 - can two be used in tandem?
No problem using multiple ED4s, just make sure triggers that are going to experience crosstalk are connected to the same unit.
