Splitting an output between bell and kick
Hi. Is it possible to split one input between the bell input on a 3 zone metal ride and the kick? They are both single piezo triggers. I thought you could do this but don't see a way in the gui. Thanks.
Re: Splitting an output between bell and kick
Yes, just set the bell / kick input to dual mono first. The bell must be connected to the ring connection.
Is this also possible with a switch bell? (Lemon 18). I had thought mine was piezo, and have it set up that way which bizarrely works fine, but if I change it to the 3 way ride with switch, can I make use of the dual-mono input?
