Best power supply for edrumin10?
Luckymethod
Post by Luckymethod »
I'm looking for a power supply to feed my edrumin10 when it's not connected to USB, what's the favorite solution around here? Could someone point me to a good quality power supply that's compatible?
Thanks!
Re: Best power supply for edrumin10?
Look no further than page 5 of the manual.
DC Power Connector
brave_kilby
Post by brave_kilby »
https://www.thomann.de/intl/mooer_table_adapter_eu.htm
I am using this one to feed my daisy chained edrumin 10s. Not sure if it's "the best", but it works well and I needed something with a long cable.
Luckymethod
The mooer looks good, I'll check that one out.
LooseSends
Post by LooseSends »
In my case, I was powering my ED4 through the USB host of the ED10 but recently it was getting erratic and not showing up the ED4 in the control software, so I simply plugged the ED4 directly into the hub going to the computer instead of through the ED10.
I hate the idea of using a bulky power brick when there's more than enough power through the USB midi port itself but there are situations where you might need separate power. You don't really want an overkill power brick for something that requires only 70 milliamps (for ED4) or 100ma (ED10 up to *600ma if you want to use the USB Host port too. The manual has different milliamp requirements depending on which page you're reading lol) of supply @ 9v. You could probably scrounge some wall wart lying around that would do the trick and be less bulky than that thing.
So at max you might only need only 1w so that big power brick is kind of overkill really.
evh0u812
Post by evh0u812 »
Any reason you can't just use an old USB phone charger and a USB printer lead? Seems everyone has a dozen old chargers lying around. Works fine for me.
That's what I recommend.
