I use some Alesis drum pads and I tried to split them into one EdrumIn input with a stereo splitter.
I use mono cables.
The Input Mode is set to two separate pads and I can only hear one sound (the same sound) coming out of the two pads.
The Pad Type is to Mesh pads and I can see two icons on the Input Selector.
I would like to assign diffrent sounds to the two pads using one input on the EdrumIn.
What am I doing wrong ?
Thank you,
Splitter
Re: Splitter
Sounds like you don't have proper stereo to dual mono splitter. From your description, it sounds like you have a stereo to dual stereo splitter.
Re: Splitter
Thanks Rob,
Do you have a link to the proper splitter so that I can order the right ones ?
Thanks a lot!
Thanks a lot!
Re: Splitter
Hosa YPP-117 is what I use and it works perfectly
https://www.amazon.ca/Hosa-YPP117-inch- ... 70718&th=1
