Since the eDRUMin 4 has four trigger inputs, does that mean that by connecting 4 x Yamaha XP80 triple zone pads we can have access to 12 different sounds with the device ? (12 diff midi notes sent).
Thanks,
Francis.
eDRUMin 4
Re: eDRUMin 4
wow cool, rob your products are amazing, i'm reading up on the midi expression now, might be something i need as well, going through the manual.
Re: eDRUMin 4
There are still people reading manuals these days?
Kudos to you... you are a species in danger of extinction.
Re: eDRUMin 4
So true! I actually read manuals (if available) before I purchase the product. Manuals have a way of cutting through the marketing BS and telling you how the product really works.
Re: eDRUMin 4
Looking to buy two eDRUMin 4.
Will everything work with an Alesis Strike module and pads/cymbals ?
Thanks.
Thanks.
Re: eDRUMin 4
If you're hoping to trigger sounds on the strike, that would be pretty tricky with an ED4.
Re: eDRUMin 4
So you don't recommand it with a Strike module ?
Thanks.
Thanks.
