Feature request: user preset velocity curves
A feature I would like to see is user presets for velocity curves. Maybe four user defined presets for the curves so I can apply the exact same curve to multiple trigger inputs instead of configuring each input and trying to make the curves the same. Useful even as a starting point before minor tweaks to individual inputs.
Re: Feature request: user preset velocity curves
It's already implemented. Just save a trigger preset, and when you go to load, only check 'Velocity Curves'.
