I just hooked a Roland VH-14D Digital Hihat directly to my computer to see if, unlike the digital snare or ride, it sends CC messages and you know what? it does! Here you can see it in action: https://youtu.be/eYFM2ZITUak
So if you are lucky to find a VH-14 and want to use it with your edrumin10 it will work perfectly connected to the USB host.
Roland digital pads with edrumin revisited
Re: Roland digital pads with edrumin revisited
That’s really useful knowledge - now I just need to stumble across a reason to be able to spend like £700 on some hats!
DAM I wish I was either rich or a pro drummer that could justify it!
It actually really annoys me that they let the hi hat send CC messages but doesn’t let you for the snare or ride - snare in particular!
Oh well; it’s probably for the best - I’m too cheap to buy Roland anyway - why do you think I went for the edrumin! It’s got to be as close as you can get to all the trigger parameters of a roland module, without all the added stuff I don’t need like….sounds haha. That sounds really counterintuitive doesn’t it? A drummer wanting to buy everything for a kit but not the sounds that come out of it haha you know what I mean tho!
I was hoping that CC04 open/close would be sent by the unit and it's good to see that is the case.
However, does the digital hi-hat send the head trigger positional CC over the USB connection? It supports positional sensing across the surface of the cymbal with a Roland module. That would be the equivalent CC message to the ones that the snare and ride don't send. I get the feeling the hi-hat won't send this either but it would be good to find out!
Nope, only CC4 for open/close…
Here is another video showing the digital pads connected directly to my computer and everything else to a td-50x, triggering Fields of Rock.
https://www.youtube.com/watch?v=KTDVsK0Imts
This is the midi that's being sent by the VH-14 Hats to the outside world.
thanks for posting this lalo. you say (and seem to show) on the vid that you get positional sensing with the snare. can you confirm that and also talk a little more about it (how many zones on ps, how reliable is the snare triggering, how difficult to set up, connected to computer directly or via hub, etc). The Roland digital snare is probably the one piece of hardware that i would really love to have and you have got me potentially interested in buying one againlalo wrote: ↑Wed Feb 23, 2022 3:49 pmHere is another video showing the digital pads connected directly to my computer and everything else to a td-50x, triggering Fields of Rock.
thanks
Hi. No, there’s no positional sensing, I need to talk louder and clearer, and of course English is not my first language…
Apart from that, it feels and plays great
thanks for the clarification - appreciated
your voice is a bit quiet on the vid but the problem is more likely to be my ears. your English is great
This is the edrumin10 with digital pads connected to the computer, I've achieved what I wanted, bye TD-50X.
https://www.youtube.com/watch?v=UJNbjsEVIUw
