15" Lemon cymbal to hot
my 15" Lemon cymbal I use as HiHat is also quite hot.
The bow signal is ok. When hitting the edge the piezo signal is clipping and so giving already 127 velocities on medium hits.
Tests with my snare-is-to-hot-resistor-bread-board show,
that it will be good with a resistor in series, again.
With the edge scaler set to 0.7.
Anybody of you guys having such issues?
I mean, I got 5 of these cymbals, and the other four are ok, also with a high signal but not clipping.
Maybe it's a mechanical crash cymbal on hihat stand vibration problem...I don't know.
Thanks for your comments!
