Go eDrum HH Controller
KSJM89
Post by KSJM89 »
Looking at a cheap solution to move to eDrumin 10! does anyone use or know if the Go eDrum HH controller paired with a PCY135 would offer a good solution to having a fully working high hat that could be used with SD3?
other option is to just buy a Roland VH-11, however I would have to wait longer.
Any input/help appreciated, apologies if this has been discussed before search yielded little info :)
KSJM89
Re: Go eDrum HH Controller
Post by KSJM89 »
I have seen the controller is compatible, after user experience preferable with SD3, Cheers!
thenewdrummer
Post by thenewdrummer »
KSJM89 wrote:
Sun Aug 15, 2021 10:13 am
I use it with a lemon cymbal and ezdrummer and it works great.
KSJM89
Post by KSJM89 »
thenewdrummer wrote:
Sun Aug 15, 2021 11:27 pm
Awesome! what did you run previously? did you go for the Roland version or the Yamaha variant? I'm guessing I need the Roland one to relate it to a setting in the DSP program for eDrumin?
I have it with dual DIY metal cymbals.
I find the calibration range is quite short, and the chick / splash a little tricky to dial in, but generally very playable and still much better than any other edrum I've tried.
thenewdrummer
KSJM89 wrote:
Mon Aug 16, 2021 7:10 am
The Roland one.
KSJM89
Post by KSJM89 »
Tue Aug 17, 2021 3:22 am
The Roland one.
Hi, I haven't committed just yet as I may just get a VH-11 for ease, however a Roland one would be the be the best I think to get it to relate in the DSP program. I currently have a Yamaha RHH135 but have found out it isn't that great for use with SD3 and eDrumin 10. If i sold my RHH135 and 2 x PCY135's i think i could just buy the VH-11 and have no worries at all then.
What's you plan?
