Jobeky Triggers
mrantarctica
Jobeky Triggers
Post by mrantarctica »
Hi all,
Looking for some feedback on Jobeky triggers. Read on some posts that out of the box they are too hot and need modification. Just wondering if users have used their trigger systems and implemented them with good results and whether modifications were required.
sdbro75
Re: Jobeky Triggers
Post by sdbro75 »
I am using Jobeky centre-mounted triggers; I haven't had any noticeable issues, I followed what another forum member had said they did, which was to lower the position of the trigger slightly when the signal appeared too 'hot.
That said, it's a slow process for me in figuring out the best configuration for my e-drums, ironing out issues, etc.
mrantarctica
Re: Jobeky Triggers
Thanks. This is what I thought also, and have confirmed with some others.
thedrumdoctor
Contact:
Re: Jobeky Triggers
Post by thedrumdoctor »
I have Jobeky centre trigger on my Snare, the side triggers on Toms and the rail-mount trigger on the BD. All behaved very well in a TD-20 and I have no fear whatsoever about how they will work in the EDrumin software. The parameter tweaking looks fantastic and can't wait to get stuck in configuring them.
thenewdrummer
Re: Jobeky Triggers
Post by thenewdrummer »
You can see it in action with edrumin in some part of the video here. I experienced the same behaviour with the bar one : https://youtu.be/mKJpXU11n6Y
Re: Jobeky Triggers
Sorry, no time to find your issue in that 17 minute video. If you can point me to some specific time in the video I will have a look.
fajan
Re: Jobeky Triggers
Post by fajan »
thedrumdoctor wrote:
Wed Jul 28, 2021 4:54 pm
Did you already try out this setup with an edrumin?
