Behringer FCB1010 MIDI foot controller usage
Hi guys,
I grabbed a used Behringer FCB1010 MIDI foot controller and actually - because the possibilities are endless -
I am not sure what to use it for. :roll:
I thought of switching FX in Superior Drummer 3 and control e.g. delays or sends with the expression pedals.
But then I have found a nice script to use it in Ableton Live for controlling the Looper and clips and scences.
https://www.youtube.com/watch?v=hbeI5HH9bNQ
And I could use it, to change the eDrumIn note banks.
Does anyone of you use this beautiful piece of gear, too?
If yes, how do you use it?
Greetings
Manuel
Re: Behringer FCB1010 MIDI foot controller usage
Hi Manuel,
I decided a while back that the FB10101 is the foot pedal I will be purchasing (used) at some point. I've read a fair amount of articles about it. Many people on the Cantabile forum use it - there is some good information about it there.
Guitar players using it to control VST amps and effects often upgrade the chip in it. I think it's so the foot switches can latch independently.
For control of the edrumin by itself I think a traditional momentary two button foot switch is all you need to change banks up and down.
I think I will use it for all kind of stuff together, I have 10 banks of 10 presets. :D
I would like to use the MIDI PC messages to change the note assignments.
You know, the advertising for the MIDI products always say "endless possibilities" but, that's not good. :D
Anyway, thanks for your comment.
