Saving a bank?
Saving a bank?
What is the best way to save my entire bank for backup or for xfer to another edrumin? Do I have to export each pad preset individually?
Re: Saving a bank?
If you are using version 1.5, you can save a device snapshot. But if you are going from an ED10 to a ED4 or vice-versa, you will have to save the inputs individually.
Re: Saving a bank?
I'm on an eDrumin10 V2 and using 1.5.22 but I can't seem to find the device snapshot button/toggle. In the preset manager there is only individual pad settings. I'm using a mac.
Re: Saving a bank?
It’s a little tricky. When you are on the Presets screen tap one of the device icons at the top so that it gets a green border. This switches the Preset page to devices instead of pads. Then tap New Preset to create a new snapshot of the selected device.
Re: Saving a bank?
How do you apply an imported preset? The only options I see are 1.Overwrite preset 2.Export 3. Delete
I now have a second eDrumin (4) and trying to clone it from the backup I made of the other one.
**DISREGARD - Double-clicked on the image file and voila... ***
