does edrumin work with ALTERNATE MODES DRUMKAT?
ELITEME4200
Post by ELITEME4200 »
Does EDRUMIN WORK with an alternate
MODES DK10?
Re: does edrumin work with ALTERNATE MODES DRUMKAT?
I'm not familiar with "Alternate Modes Drumkat". Can you give me more information?
ELITEME4200
IT'S A MIDI CONTROLLER, THAT WORKS WITH FSR PADS. IT HAS MIDI IN AND OUT. ALSO, DOES EDRUMIN WORK WITH FSR POLE PAD PRO'S BY DRUMTEC? THANKS, ROB!
I don't think eDRUMin will work with FSR pads, but certainly it'll have no problem interfacing with other MIDI hardware.
ELITEME4200 wrote:
Sun Jun 13, 2021 5:28 pm
MODES DK10?
Depends what you want the eDRUMin to do for you?
I see the DK10 has MIDI in, so, yes, you can plug the eDRUMin into the MIDI in of the DK10.
I'm sure you can use it to have the snare drum sound from a real e-snare. So, a duplicate of one of the pads.
But, if you want more sounds, like 2 different snares, then I have no idea if the the DK10 can add more than the number of pads it already has.
That should be a question on the KAT forum.
ELITEME4200
THANK YOU!
ELITEME4200
Wed Jun 23, 2021 1:59 am
THANKS
ELITEME4200
perceval wrote:
Wed Jun 23, 2021 3:35 am
MODES DK10?
THANK YOU.
