Jobeky rubber cymbals support(ed?)
Pejannl
Post by Pejannl »
Hi. Does anyone have configuration information to use Jobeky Rubber cymbals? I have a three zone ride (two connectors)but can’t get edrumin (4) to recognize anything but the ride. No edge, no bell. Can anyone provide a clue how to configure this?
Tia, Peter
Re: Jobeky rubber cymbals support(ed?)
How is the cymbal wired? Do you have a link for the cymbal?
Pejannl
Post by Pejannl »
Rob wrote:How is the cymbal wired? Do you have a link for the cymbal?
I don’t know how the cymbal is wired. The url for the cymbal is https://jobekydrums.co.uk/product/15-6- ... er-cymbal/
Cheers, Peter
Jobeky's gear is quite non standard. You notice how they have 5 versions of that cymbal depending on which module you plan to use? My guess is that you'll want to use one of the Metal Cymbal pad types.
Pejannl
Post by Pejannl »
Rob wrote:Jobeky's gear is quite non standard. You notice how they have 5 versions of that cymbal depending on which module you plan to use? My guess is that you'll want to use one of the Metal Cymbal pad types.
I don’t know whether they hve five versions or whether they ask about the module only for statistical purposes.
Maybe you can give me some directions which options I might try to get it to work, rather than advising me to buy yet another cymbal. I would appreciate that.
Sly
Post by Sly »
I'd say to keep calm, I think this was a setting advice, not an advice to buy another cymbal.
Rob wrote: My guess is that you'll want to use one of the Metal Cymbal pad types.
Personnaly, I would say that this Jobeky cymbal has a bell switch... So Metal cymbal cymbal type should not really help but give it a try, I'm maybe wrong.
In fact, I think those Jobeky cymbal are just the same as the "lemon cymbals" found on alibaba. They're known to have compatibility issue due to an error in the wiring... Maybe you should first ask to jobeky how your cymbal is wired. That should help a lot more.
Pejannl
Post by Pejannl »
Sly wrote:I'd say to keep calm, I think this was a setting advice, not an advice to buy another cymbal.
Ok. Thanks. I’ll ask them and see what they come up with.
Pejannl
Post by Pejannl »
Jobeky confirmed to me that the ride cymbal is wired the same as Roland cymbals.
But when I choose a Roland ride cymbal then the eDrumin only shows a single cable whereas my ride has dual connectors. That kinda leaves me clueless.
Sly
Post by Sly »
I don't really understand your problem, do you actually set the input to stereo ?
Check this short video explaining the problem with lemon cymbals, you'll see that your cymbal is exactly the same except the rubber covering. I'm not sure it will help you though :
https://www.youtube.com/watch?v=eAe4m7QKOoI
Pejannl
Post by Pejannl »
Sly wrote:I don't really understand your problem, do you actually set the input to stereo ?
Thanks, mate. I know this video and had already checked the wiring.
The problem which I encountered was caused by something funny in the software interface. I was looking under “cymbals” for an appropriate setting, but the preset for the two-wire Roland compatible cymbal is listed under “Roland” and not under “cymbal”. Food for improvement...
Now I’m waiting for the midi cable to arrive and then get the notes into my drum module. Fingers crossed!
