Hello,
I'm considering purchasing the 4 input edrumin unit. I'd like to use a Roland VH13 hi hat with this unit.
Does the control software have a preset for the VH13?
Also, the VH13 usually connects to a Roland module via two TRS cables. I'm assuming one of these cables would insert into the edrumin foot pedal input, while the other would insert into one of the pad input jacks??
I'm wondering how much work it would be, to set up the edrumin with a VH13.
Thanks
Dan
Roland VH13 Hi Hat Preset??
Re: Roland VH13 Hi Hat Preset??
Hi Dan,
There is a preset for the VH-13 hihat cymbal, but not the pedal as this functionality hasn't been implemented yet. It's coming in the next version, but that's still a couple of months out.
That being said, setting up the VH-13 without a pedal preset is easy enough to do, especially considering I've got a video about setting it up. I personally use a VH-13 and it works great.
