I might be doing something wrong, but if without "send to self" enabled I wasn't getting the ED4 midi out the ED10 midi (ED4 midi out -> ED10 midi in -> ED10 midi out)
eDRUMin 1.6.1 BETA
Re: eDRUMin 1.6.1 BETA
I just tested and it looks like you're right. I don't think its a bug, but that might cause trouble with the iOS app. Need to think about it some more... I looked the code over and I think it should be fine.
I tested this configuration today, and while I didn't test extensively, I didn't notice any issues or experience any crashes (ios 15.1).mmarco wrote: ↑Wed Nov 10, 2021 9:32 pmare there known issues with the iOS app and ED10 + ED4? I have both connected to a powered USB hub, which in turn I connect to the ipad via the USB kit. If only one of them is connected, everything is fine, if both are connected the edrumin iOS app crashes immediately (at least it crashes immediately now, when they were factory reset it did connect to both together, but after I calibrated a couple of pads it crashed and it hasn't run anymore since).
