eDRUMin version 1.3.2 BETA
lalo wrote:
Rob wrote:Lalo, do you think you could give me a step by step procedure to reproduce the issue?
at start up the exclamation mark on the ride bell connected to input 10 of the edrumin 10 appears
This has happened for a couple of builds now, and is unrelated to the host port change.
I've tried to fix it before, but couldn't find the problem. Having a recipe to follow to reproduce the issue would help immensely... preferably one that started with something like this.
1. Reset inputs 9 and 10.
2. On input 9, set the pad type Roland 3 zone cymbal.
I resetted the input as roland and the compatibility issue was gone effectively, I then set it up again as a jobeky 3 zone metal cymbal and no compatibility issue appears, so it's fixed yeah.
But now I have the following issue/bug: all my edge hits trigger at max velocity 127, no matter how hard or soft it always triggers 127, I calibrated my cymbal which brought down the gain from 9.3 to 4.9 but still the same, all edge hits are 127. It's a drone 20" low volume converted with piezos on the bell and bow, switch on the edge.
I should have some time tomorrow to check things over.
Using Jobeky 18" Ride on ED10 with firmware 1.3.2.9
1. Plugged bow into input 9, bell into input 10.
2. Reset inputs 9 and 10.
3. Set input 9 to "Metal 3-Zone Cymbal.
Result: Played fine, could trigger edge velocities below 127. There's no bug and no issue as far as I can tell.
As for your edge hits being all 127, have you turned down your edge scaler? Probably should set it at 1 for a metal cymbal.
Well, now disaster strikes, I lost the bell input, the bell doesn't trigger anymore, no matter which preset or resetting the input, tried the same cable in another input and it works, cymbal is connected to input 9 and 10, 9 bow/edge, bell 10, hitting bell always triggers the bow, no matter if I set the bell scaler to 9... I never learn... if ain't broke don't fix it....
If you give me clear steps to reproduce the issue, I can check and see if there's problem.
Input 10 is now fried, whatever I connect into it and try to select the pad type crashes the app every time, I reset the device, plug the ride to inputs 1 and 2, it works, but input 10 can’t change the pad type, that’s where the bell was connected before.
You're on version 1.3.2.9 and you've tried to do a 'factory reset' (reset the entire device), and input 10 still doesn't work? Is that correct?
(Probably unrelated, but I've had multiple hard crashes too trying to switch pad settings on input 10 as well, when I added a PD-7. I was able to get around it by loading an unrelated preset, then switching from there.)
