eDRUMin version 2.1.1 BETA
tjheller
Contact:
Re: eDRUMin version 2.1.1 BETA
Post by tjheller »
Yes!!! That feature looks very usefull. Especially to those with ed10 or the "coming soon" ed8 (I think) Is there any chance in 2.2 there could be support for more than 4 ed4's. I'm probably an outlier but I really like keeping cable clutter to a minimum so I have 8 ed4s strategically placed around my kit. (good sized kit) I've currently got 2 banks of 4 ed4s into 2 different usb hubs and have to switch between the 2 when editing. I have a 3rd usb hub that the 2 before mentioned hubs are connected to for switching back and forth between them. I also have a midi merger taking the 8 midi outs from all the ed4s back to the computer for VST use. Power is being provided to the ed4s through usb as the hubs are powered. This solution works fine but is little clunky and could be streamlined if the software could handel more ed4s simultaneously. I'm not sure if it is even possible. Thanks for all you do Rob. The edrumin is an amazingly versatile device already and I'm happy to keep using it the way I am but it never hurts to ask.
hb1980 wrote:
Fri Jan 20, 2023 8:46 pm
Thanks Rob. I hope it all goes well with the new hardware.
Not had much of a chance to play lately but other than the compatibility warning all seems to be well with this build.
Fixed for version 2.2
mrmbira
Post by mrmbira »
There seems to be a problem with the position setting in version 2.1.1.5 on windows 7. I think this worked better in earlier versions. (It may just be something i am doing wrong, if so please let me know how to do this.) Now it won't let me go from selecting one end of the green part, you can expand or shrink, to selecting the other end. When one side has the white line (is selected) it will work fine to drag from that side but then I am unable to select the other side. after many tries it may finally switch to the other side but most often the whole green part moves first from where I had set it at the other end. Is there anyway to make this easier to set? thanks mbira
I think you're right. I remember noticing that. I may have fixed it already, but I'll double check.
UPDATE: Fixed for version 2.2
