eDRUMin version 2.2 BETA available
mrmbira
Re: eDRUMin version 2.2 BETA available
Post by mrmbira »
Tue Feb 21, 2023 7:41 am
No independent curve for positional sensing. Each input only has 4 curve settings so if it's in dual mono, the most you get it two per piezo. I can't remember how I worked that out though.
Ok good to know. I thought it must be a glitch because the manual seemed to say every articulation was independent: "An independent curve can be setup for each articulation of a pad".
Is making the positional sensing independent something that you could do easily? I think it would be quite useful. I use the different sensing zones to play very different samples. Like one pad might be a conga and the 3 zones would trigger; open tone, slap and bass. So being able to adjust the velocity curves separately can make the instrument sound more realistic. thanks, Mbira
No going to happen, sorry.
mrmbira
Post by mrmbira »
Tue Feb 21, 2023 2:49 pm
that's fine Rob this still works much better than I had hoped!
AKA Wayne
Post by AKA Wayne »
Tue Feb 21, 2023 7:44 am
Changes in build 7
  • Fixed disappearing flash memory icon issue.
  • Fixed issue chocking metal cymbals on ED4R1.
Amazing! Thanks so much for bringing my chokes back to life!
Changes in build 8
  • Connecting flash memory will no longer cause the eDRUMin to stall while it opens the filesystem.
mrmbira
Post by mrmbira »
Seems to be a glitch when creating a device snapshot with custom notes. Until today it was working that I didn't have to use custom options for presets and all loaded fine, now that doesn't work at all. When I double click on the new preset it will come up with kit pieces, no dual mono, and none of my settings.
If I select use custom load options with these selected: input settings, note banks, velocity curves, and I highlight all pads. It has the same problem but if I reboot the device and restart the control It will sometimes load what was supposed to be in the preset. This is not working now and may have been only what was loaded on edrumin before. I have 2.2.0.5 and thought it had been working fine but maybe it was the previous version that worked. Win 7 with all dual mono pads.
***UPDATE: I updated to 2.2.0.8 and so far saving device snapshots seems to be working again. Not sure what was going on?
Can you take a look to see if there is something funky with saving presets with custom notes? thanks, Mbira
Changes in build 9
  • Reverted the background initialization of USB flash drive because it was causing stability issues.
mrmbira
Post by mrmbira »
mrmbira wrote:
Sat Feb 25, 2023 4:39 pm
Still having problems with snapshots not having any settings or notes in them when I create a new one. Even though the control app was just opened I then had to restart it, then creating the snapshot worked this last time. Not sure if it is something with my setup or a glitch in your program. thanks for any help with sorting this out.
I'll have a look.
mrmbira
Post by mrmbira »
Sat Mar 04, 2023 3:38 am
I'll have a look.
ok thanks, let me know if you find anything or not. I have only used custom notes and dual mono pads.
