I understood it as a change in the function of the sustain (momentary) pedal.
It never occurred to me that someone might own a latch pedal, because I don't have one.
Thanks, Rob!Rob wrote: ↑Fri Mar 11, 2022 1:22 amI'm posting build 27.
- Added an additional HSS control to improve hotspot targeting for some pads.
- Preset Manager remembers last selected preset.
- Preset Manager will no longer start showing Device Presets when using auto-select causes the currently selected device to change.
- Updated manual to include information about the new controls added for hotspot suppression and positional sensing.
- Added a Reggae EZX factory drum map.
Rob wrote: ↑Fri Mar 11, 2022 1:21 amIs the eDRUMin connected connected using a hub? If it is, try connecting without the hub, or try changing USB ports. Also, there should be a file called MEC_Log.txt on your desktop. If you email it to support at audiofront dot net, I'll have a look and see if there's anything in there that might explain the problem.
