Email me at support at audiofront dot net
Rob wrote:Power cycle and see if it comes back up.
Trigger module is working fine; control app is showing a default screen with four inputs, greyed out.
I changed a compiler optimization setting in that build. Probably shouldn't have. Don't update the ED4. Mine hung. I'll make a new build with the old optimization setting and we'll recover your device.
Rob wrote:Don't update the ED4.
Hah, too late! I always update both devices. :lol:
I took the ED4 to another computer with nothing else connected to it, and the update went through. All is well with Build 28.
I've had ED10 with another ED10 in the Host port running on iOS for 12 hours now without issue. I'll keep it running all day and play when I have time, but I think it's really resolved now.
Polyphonics
Post by Polyphonics »
Rob wrote:What firmware were the modules running?
Sorry I took a while to respond, it's just the one module which is on 1.3.0.12, I think the others were just on 1.3
Here should be a video of the calibration issue: https://drive.google.com/file/d/1MrNnhJ ... sp=sharing
If you can view the video, it will show how the green bar varies greatly in size, it would do that at random.
Can you update to the latest version. If the problem persists, can you make another video showing the entire UI so that I can see what the pedal sensing and polarity controls are doing.
Polyphonics
Will do,
On the other settings, I always turn pedal sense off but it would periodically turn back on (not always when this glitch was happening either), polarity is reversed or auto, I often had to change it back and forth to "wake up" the pedal
No more crashes or locks here since yesterday when I installed build 28.
