eDRUMin 1.2 BETA is now available
Re: eDRUMin 1.2 BETA is now available
vandroiy wrote: My PCY155 seems to work, the other 3 cymbals choke a lot when I hit them. And when it happens, it stays like that. It honestly feels like a physical issues with the cymbals (if it had not happened on 3 at the same time)
Also, all 3 cymbals seem to trigger the bow a lot of the time I hit the edge.
Can I get you to capture some data for me? Make sure auto-select is on. If you right click on the eDRUMin logo 5 time, and then left click on it once, a record button appears over the velocity curve area. Press the record button and hit the edge of one of your troublesome cymbals about 20 times (capturing the false triggering about 10 times should do). Then press the record button again and a file called ED_Data.hex will appear on your desktop. You can email it to support at audiofront dot net and I'll take a look at what's going on.
vandroiy
Post by vandroiy »
of course. sent you 1 file with the Miss-Triggerings and chokes, and one after a Downgrade to the old Firmware (consistently triggering the Edge of the Cymbal correctly).
I am posting a preset of the PCY135, if that can help.
I can confirm there is a bug with choking. I'm pretty sure I've resolved it with build 5. I'll post build that once I get confirmation from vandroiy that the issue is resolved.
Abou
Post by Abou »
A nice future visual feature may be the possibility to rename pads and cymbals. Like in this image:
https://www.dropbox.com/s/khbzbg6uv1bek ... e.png?dl=0
But with a better design ;-)
Concerning issue with choke, I had it a several times with my 2 PCY155. But I didn't try yet the new BETA firmware.
Not a bad idea, but transfering text between the device and the UI is very inefficient. If the user instead selected a name for the pad from a list possible names, that would be doable.
And maybe keep'em simple, like :
- Pads: S1, S2, T1, T2, T3, T4, K
- Cymbals: HH, R1, R2, C1, C2, C3
I could even have a corresponding image to go with the text.
Changes in Build 7
  • A possible fix for reports of unintentional choking on cymbals
  • Numerous UI improvements to reduce CPU usage.
Abou
Post by Abou »
perceval wrote:And maybe keep'em simple, like :
Personnaly I prefer an entire word :-) maybe let the user enter the letters he wants :-)
