Roland BT-1: by default in "switch" mode (i.e. with internal crosstalk cancellation enabled; reduced dynamic range)
When used in dual mono mode, *and* reversing polarity or using a splitter cable, Tip will enable "sensor" mode.
Roland PD-80R: head/rim/rimshot
Thanks for that. At some point I'll add a setting for mono mode so that you can select either the tip of the ring signal. That will eliminate the need for the adapter.
Roland CY12 R/C
This cymbal _almost_ works with bell sense on one input, but triggering on the bell is not accurate or consistent. Tried with cy8, cy13 and cy15 setting.
Adding Goedrum HH controller and dual zone 13 pad to this list. No bell sense though.
MWJT42 wrote:Adding Goedrum HH controller and dual zone 13 pad to this list. No bell sense though.
I’m not too familiar with Goedrum so when you say “pad” but talk about “no bell sense” can you clarify? Is this a 13” Goedrum cymbal pad you’re talking about?
Yes,
The goedrum GHC HH controller works very well, a great cheap alternative to the VH11.
The 13 (older model) pad functions well too, but doesn’t seem have bell sense - not that I want it on a hi hat.
Using drone halo triggers, the rims are not that responsive, the rest works ok.
Roland CY12R/C is now working as a three-zone ride with a single input to the eDRUMin (using the CY13R Bell Sense setting).
Ratamacue
Post by Ratamacue »
Roland CY-5
Roland KD-7
ayjaysmith
Post by ayjaysmith »
My pintech hihat does not work unless I unplug the bell.
