eDRUMin version 2.1 BETA
Re: eDRUMin version 2.1 BETA
Posted build 2.
  • Fixed an optimization issue with Dual Mono inputs.
  • Fixed Alesis Drum Map.
UPDATE: Seems like the Alesis Map isn't being updated for some reason....
I posted build 4.
  • Fixed Alesis drum map.
  • Fixed a possible crash.
  • Fixed an edge sense issue.
Luckymethod
Post by Luckymethod »
found an error in the Superior Drummer map, crash 1 is mapped to the ride.
see video: https://photos.app.goo.gl/QaTDPEsShWnMebYn6
Luckymethod
Sun Sep 18, 2022 3:35 am
I posted build 4.
The drum map is ALMOST there. There's still a couple issues.
Ride
1. The bell is mapped to 26, should be mapped to 53
2. The choke for is mapped to 0, not sure what the value should be but the crash is 34 and it works.
Everything else seems to work fine, thank you so much for adding this, it's really nice to have it out of the box.
So the other issues with the UI not being responsive are fixed as well?
UPDATE: Map is fixed for the next build.
Luckymethod wrote:
Mon Sep 19, 2022 3:02 am
I think that's more likely an issue with the particular library you have loaded. SD3 mappings for various expansion packs are all over the place--one of the major reasons why I implemented maps in eDRUMin in the first place.
Luckymethod
Mon Sep 19, 2022 6:26 am
Happens with the standard library, a couple expansions and all the ezdrummer 2 libraries. I would say it's pretty consistently wrong in the same way.
Luckymethod
Mon Sep 19, 2022 4:02 am
I figured that one out: happens when i connect the USB cable and the power supply is also connected at the same time. If I disconnect the power supply it starts working immediately.
Is it a known limitation or can it be fixed?
I'm not seeing the issue here. What are you using for a hihat controller? Does it have an external power supply?
Luckymethod
Tue Sep 20, 2022 8:51 am
is this question for me? I have a Roland VH13, no external power supply.
