eDRUMin version 2 Alpha
mrmbira
Re: eDRUMin version 2 Alpha
Post by mrmbira »
Ya I guess I would like to give it a try. This problem has stopped any progress i was making so i guess it is time to make the jump to v2. thanks, Mbira
Changes in build 23
  • Added Mimic Pro drum map.
  • Fixed issue with hot plugging devices or updating firmware and wrong drum map being displayed.
  • Fixed after updating a device connected to ED10 host port, device shows pads greyed out.
  • Fixed dual mono pads with positional sensing as note not displaying note values.
  • Fixed positional note can't be auditioned.
  • Fixed positional note for ring of dual mono input not always working.
  • Fixed positional note not always lighting up the correct note control.
I've installed alpha 22 on my edrumin10 and setting up my drone optical controller, in the pedal editor advanced mode I've seen the "Always Send On Closed" from 1.6 is missing, that causes my controller to not triggering the pedal note when closing the hihat slowly from any level below 5, it only triggers pedal when closing it from 6, using hihat levels of course.
I can probably put that back in there, but lowering your travel control will probably get you what you want.
yeah, I put it down at .40 from the default .68, icreased the gain from 30 to 50 and it's much better now, thanks
andurillek
Post by andurillek »
Hi, I've only had ED10 for a few days and I've thought of a lot of things I'd like to have there. Then I looked here at the forum and found that version 2 was being worked on and there was what I wanted ... Rob, you're great. And the community too. Thank you all... :D :D :D
What features in particular are interested in version 2?
Dadwrshpdrum wrote:
Thu Feb 24, 2022 1:40 am
Thu Feb 24, 2022 1:03 am
I've updated the Roland map and it'll be included in the next build.
I tested 'Send maps to all devices' on Windows and macOS and failed to reproduce your issue. You were also having auto-select issues? I wonder if perhaps the ED10 doesn't like the hub you have plugged into the host port. My setup also uses a hub in the bac of my ED10. I have an ED4, a MIDI Expression, and a iConnectMIDI4+ plugged into it. Here's a video I made to confirm that I am not able to reproduce the issue.
I’ll try it without the hub this weekend. Away from computer for a couple days. I do have one of the ED10R1s with some sort of USB issue. I forget what it was,l. I doubt that is it because I have no other issues. Like you said it is likely my hub.
I’ve tried this multiple times now with build 22 and 23 (the latest version). I cannot get the drum map to be sent to th3 other eDRUMin unit. My baseline set up is a powered USB hub connected to the ED10 R1 USB host port. The hub has a TD-17 and ED4 connected to it. When I change the ED10s drum map to SD3 (for example), and the ED4 is a Roland drum map, I select the eDRUMin logo. The “send drum map to other midi devices) is not green. I select it anyways. The menu closes. I click on the ED4 and the drum map is unchanged. I go back to ED10 select the logo and the option is now green. So I select it, but again nothing happens.
Troubleshooting steps:
1) disconnected TD17 from the hub
2) connected ED4 directly to USB host port of ED10
3) connected both eDRUMins to USB hub and connected hub to computer
4) connected both eDRUMins directly to computer
None of these worked.
mrmbira
Post by mrmbira »
Hi Rob, I installed the v2.23 and the firmware and that seems to have fixed all the problems I had with positional sensing an dual mono inputs. It is working great now. Thanks for the quick fix. I Didn't realize that you had the manual included or i would have upgraded sooner. So cool ... it will take awhile to try out all the new features.
However now I am experiencing a problem with my Alesis 2 zone stereo snare pad with positional sensing. I will play around with it and see if I can make the problem go away. If not I will try to post the specifics. thanks again, Mbira
Sun Feb 27, 2022 1:39 pm
shallow rim shots if you could get them in there along with all the other changes
