I just checked here, and there's definitely a bug with the linked hihat indicator when editing a hihat on a device that's plugged into the USB host port. Good catch. I'll fix it this morning. Shouldn't require a firmware update.
Rob wrote:I just checked here, and there's definitely a bug with the linked hihat indicator when editing a hihat on a device that's plugged into the USB host port. Good catch. I'll fix it this morning. Shouldn't require a firmware update.
Any thoughts on what I might be doing wrong on the splash? I figure if there was a problem it would be reported by now.
Give me some time. I'll fix the bug first and see if I can reproduce any other issues when the hihat is connect to a device on the host port.
Rob wrote:Give me some time. I'll fix the bug first and see if I can reproduce any other issues when the hihat is connect to a device on the host port.
Sure thing... let me know if I can help out with any data captures.
So I fixed the bug and tested splashes, and I see no issues. What hihat controller are you using?
Rob wrote:So I fixed the bug and tested splashes, and I see no issues. What hihat controller are you using?
VH-11
VH-11
I emailed you a video of what I’m experiencing. Hopefully it comes through.
I got it. It's not triggering a splash because...
1. You aren't pressing the pedal down fast enough.
2. You aren't letting the pedal release fast enough.
Also, it looks like your gain control can be increased a bit.
If you watch a video about triggering splashes on a real hihat, you'll see that you have to jolt the hihat down quite fast, and your foot cannot be be making contact with the pedal after the cymbals have come together. The same applies to the hihat input on the eDRUMin.
Ok... I’ll try to work on my technique but I feel like I’ve tried a lot of things. Getting a splash on a real hi-hat doesn’t seem this hard. :D
So I just tried it. Went as fast I could go and lifted my foot completely off of it on the up stroke. Still nothing. I can do splashes on a real hi-hat. I’m not convinced technique is the issue. I’ll have to see some video of this working. Maybe when you do your video I’ll understand it better.
