eDRUMin version 2.3.1 BETA
Luckymethod
Post by Luckymethod »
Sat Mar 02, 2024 10:00 pm
I changed the download link back to build 20. In build 21, I added support for choking on Laurin cymbals, but obviously my code needs so more work. You can install build 20 and downgrade the firmware.
Understood. The cymbals were definitely way easier to choke while before they were too hard so definitely once you get it tuned I see that becoming a positive move 🙂
Thanks for the downgrade, let me know if there's anything you need me to try I'll be happy to do some tests for you.
nemo
Post by nemo »
Hi just downloaded and installed build 20 (windows) and also upgraded firmware - to 2.3.1.19. Hope it's ok...?
Luckymethod wrote:
Sun Mar 03, 2024 6:41 pm
I have a Lemon 18" ride and can't reproduce the issue. Can you describe how you were playing the cymbal when it choke unintentionally?
I posted build 22 with a small change that might remedy the erroneous choking. If you have some time I would appreciate if you could test it out.
Gemini8026
Post by Gemini8026 »
Build 22 broke my choke :) Reverting old one. The bell on my LEmon just chokes immediately on this new build
nachocascardo
Post by nachocascardo »
nemo wrote:
Sun Mar 03, 2024 7:29 pm
Hello i´m a new user of edrumin4, where i can download the firmware en the build20 ( for example).
thanks for your response.
Luckymethod
nachocascardo wrote:
Wed Mar 06, 2024 3:19 pm
First post in this thread but it would be a bit easier if there was a canonical place for older build to check.
nachocascardo
Thanks, i didnt see in the firt time, i need glasses jejejej.
thanks again.!
Wed Mar 06, 2024 6:40 pm
thanks again.!
FWIW, whenever Rob, the developer/inventor/business person/software designer, QC team, does a new build he posts it at the top of the thread.
nachocascardo
yesterday i installed the last version build 22, and i started to setup my 2 zone snare with TRS cable, all fine, only in the POSITIONAL T (tip) i switch to R ( ring detection or compensation), the positional sensing get better, y check the AUTO save, all allright, but, if i select another input for example HIHAT and start to tweak, the R selection in positional sensing adjunt, the selection was reverted to T ( tip) selection. I think i´m doing something wrong. What is the normal procedure to save this setting, maybe i´m doing o missing some steps.
thanks in advance for all the forum, you rock guys.!!!
