So the 32 value is correct? I haven’t really had a chance to dig in yet on playing dynamics. (I’m supposed to be working my real job. )
I did confirm the bank switching issue I was having is fixed in this version. Thanks a million for that.
Rob! You are the man. I think you've included just about every request, well done! Simple / Advanced mode a very wise UI choice.
Looking forward to playing with this and feeding back.
First question - is the dual mono bell still on the same wiring, ie the right input?
Yes, thats a hardware limitation.
Seems to work correctly over here on Windows.Sly wrote:I found that the autoselect is still active even when deselected.
Just want to say "THANKS", Rob. I am not able to get to my kit for a few days but I will be following this thread closely and will provide feeedback as soon as I can.
- dsteinschneider
My first bug report . The pedal input for my hall effect sensor pedal isn't sensing pedal movement at all on 1.4.0.1. A splash triggers when I press down quickly but no pedal movement. Calibrate doesn't pick up any movement.
I downgraded which worked fine - I saved my cymbal and pads before the 1.4 upgrade and used them to get the inputs setup again.
Can you please give me more details about your hall setup so I can track down the issue?
A screenshot of your hihat settings in version 1.3 would also be helpful.
It also killed my VH-10 dead, in the sense that it doesn't track movement at all.
Downgrading also doesn't seem to work. I ran the 3.19 installer but it's still on 4.1.
I see the issue. Make sure you are in advanced mode. It's a bug. I'll fix it in the next build.
I get the same result in both Advanced and Standard mode. I'll just wait for the next build then. Cheers.
