ATV Hi Hat Issues
Molson
Re: ATV Hi Hat Issues
Post by Molson »
Great to hear - looking forward to it!
I received my edrum 10 today, it took 10 days and customs inspected and charged me 45€ extra, I've set up my DIY pads with drone triggers and it works flawlessly, but the atv 14" hihat definetly doesn't work at all, it detects bow and trigger hits but the close to open transitions sent by the controller don't trigger the CC4 notes in BFD3. I'm planning to use the edrumin 10 for a second smaller kit with roland pads so no problem there, I just wanted to clarify that the VH-13 and ATV 14" are completely different. Great device though!
The 14" hihat should work fine. Maybe try resetting the pedal input. The biggest issue you will have is from the hihat cymbals banging together and triggering bow notes over top of the foot chick. Version 1.3 (the BETA should be available by the end of this week) includes a new hihat processing mode specifically for hihats on a hihat stand.
vandroiy
Post by vandroiy »
I played both ATV Hihats for weeks with the edrumin. No complaints.
well I plugged the controller on the ped input, fire edrumin control and logic with SSD5 or BFD3 and the pedal control on CC4 doesn't do nothing, no movement from 0 to 127. what I'm doing wrong?
There's a UI bug right now on the second pedal input of the ED10. Which input are plugged into?
the ped 1
Have you tried resetting the input? If you go into the control application, is the pedal moving there?
Yes, I tried resetting it, no movement at all in the control application, using same cables as my current module, nothing moves...
Can you try the 2nd input. The UI might be unresponsive because of the mentioned bug,, but it should still send CC data.
