eDRUMin 1.2 BETA is now available
Dewaaachner
Re: eDRUMin 1.2 BETA is now available
Post by Dewaaachner »
Thank you Rob,
I'm using Jman stealth conversion kits. The ones, which are compatible for the 2box drumit five mk1.
Can you suggest a trigger preset to start with?
Cheers, Frank
Drumit5 & eDRUMin, stealth cymbal Triggers, Millenium low noise Cymbals
Dewaaachner wrote:I'm using Jman stealth conversion kits. The ones, which are compatible for the 2box drumit five mk1.
Presets aren't going to work for conversion kits. Trigger settings depend so much on build parameters, and no two builds are going to be the same. You'll just have to use the provided controls to roll your own.
Changes in Build 4
  • When loading user presets, you can now choose what elements to load (trigger settings, velocity curve, note assignments).
  • Fixed a bug for macOS that prevented user presets from being saved.
  • Fixed UI updating issues, mostly apparent on macOS.
vandroiy
Post by vandroiy »
My ATV HiHat Cymbal and both of my PCY-135 Crashes suddenly Choke all the time (After Touch). I first thought on cymbals was going bad, but it seems to be something different.
Anybody else experience this or has any tips?
Dewaaachner
Ok, thanx for the info.
vandroiy wrote:My ATV HiHat Cymbal and both of my PCY-135 Crashes suddenly Choke all the time (After Touch). I first thought on cymbals was going bad, but it seems to be something different.
I definitely made changes in this area. I will have a look today. Do you have other cymbals that aren't experiencing choking issues?
MachRider wrote:I am still playing with the velocity curves, trying to figure out what gives best feel, but right now it seems like a slight upward on the low end and pulling the max a little left to boost the heavier hits helps, but not having to make drastic, near-max-capability adjustments like before with a max gain of 7.
I did the same curve for my 16" floor tom (UFO center piezo)
I updated to 1.2 build 4 and didn't make any other changes and everything is playing well for my practicing. I had to click on maps and choose Superior Drummer again. I also had to power cycle the eDRUMin my hi-hat pedal is connected to because it wasn't responding.
@vandroiy - My PCY135 and PCY155 are playing fine - the choke wasn't working until I clicked on the maps and chose Superior Drummer.
vandroiy
Post by vandroiy »
dsteinschneider wrote:I updated to 1.2 build 4 and didn't make any other changes and everything is playing well for my practicing. I had to click on maps and choose Superior Drummer again. I also had to power cycle the eDRUMin my hi-hat pedal is connected to because it wasn't responding.
My choke is working to well ;)
My PCY155 seems to work, the other 3 cymbals choke a lot when I hit them. And when it happens, it stays like that. It honestly feels like a physical issues with the cymbals (if it had not happened on 3 at the same time)
Also, all 3 cymbals seem to trigger the bow a lot of the time I hit the edge.
I will be posting presets for the PCY135 tomorrow, most probably.
I just don't have access to my kit today.
