USB 1, 2 or 3?
Re: USB 1, 2 or 3?
A USB 2.0 port supplies at most 500 mA. The hub will use 100 mA on its own, and then each eDRUMin uses an additional 70 mA. So a hub with 4 eDRUMins hooked up should work without the hub needing to be powered.
ad_
Re: USB 1, 2 or 3?
Post by ad_ »
Rob wrote:A USB 2.0 port supplies at most 500 mA. The hub will use 100 mA on its own, and then each eDRUMin uses an additional 70 mA. So a hub with 4 eDRUMins hooked up should work without the hub needing to be powered.
So this simple device would suffice?
https://www.amazon.de/Anker-Datenhub-Ul ... B00Y211AFM
TheJay
Re: USB 1, 2 or 3?
Post by TheJay »
The four additional eDRUMin modules arrived today finally! That HUB won't be any good for me having five :|
Re: USB 1, 2 or 3?
perceval wrote:Is there anything in 2020 still using USB 1.0?
Yes, a drum module.... orange by the way, took 2 hours to copy 4gb to a pc...
TheJay
Re: USB 1, 2 or 3?
Post by TheJay »
Ouch
Re: USB 1, 2 or 3?
Well it’s actually 1.1 but still a 1 :D
