Feature Requests: Lock Feature and Dual Thresholds
evh0u812
Re: Feature Requests: Lock Feature and Dual Thresholds
Post by evh0u812 »
Rob wrote:So, I heard the sidesitcks you were talking about tonight. Using extremely low threshold, they come through. Perhaps not a full out bug, but I should be able to do something subtle to improve the situation. But boy is the drum buttery at those low thresh settings, Rolls just roll and roll and roll. I'll definitely look into this.
Yeah its addictive and hard to go back to higher settings, lol. If I could get rid of the rim triggering with those settings Id be very happy! The fact you could duplicate it means my DIY snare isnt at fault thankfully. Although I could probably mount the rim piezo on some foam double stick tape to deaden it a little. Its mounted dead centre under the main piezo so its very consistent all around the rim.
