TheJay wrote:
10×8 dual zone rack tom
12×9 dual zone rack tom
16×16 dual zone floor tom
14×5.5 dual zone snare drum
22×18 bass drum
10 inch Splash
14 inch Hi Hat
18 inch China
18 inch Crash
20 inch Ride
Cowbell
Minimum 2 but that would be single zoning a lot which I’m guessing you don’t want to do. I had to make assumptions on the number of zones on your cymbals.
Here is one way to do it with 3:
Device #1
1. 10×8 dual zone rack tom
2. 12×9 dual zone rack tom
3. 16×16 dual zone floor tom
4. 14×5.5 dual zone snare drum
Device #2
1. 22×18 bass drum/Cowbell
2. 10 inch Splash/18 inch China
3. 14 inch Hi Hat
4. 18 inch Crash
Device #3
1/2. 20 inch Ride
2 open inputs
Assumptions: bass, cowbell, splash and China are all single zone so they can be split. Ride is a 2 jack variety and will need two inputs.
Another option:
Device #1 (everything here would split the jacks and be single zone but on the toms you may be able to get the rim back using Edge sense but remember... edge sense just gives you the rim back and not a full dual zone center, rim, rimshot... I think.)
1. 10×8 dual zone rack tom/12×9 dual zone rack tom
2. 22×18 bass drum/16×16 dual zone floor tom
3. 10 inch Splash/Cowbell
4. 18 inch China/18 inch Crash
Device #2
1. 14×5.5 dual zone snare drum (all zones)
2. 14 inch Hi Hat (bow/edge assuming dual zone)
3/4. 20 inch Ride (bell/bow/edge assuming 3 zones with two jacks)
