MIDI over usb or midi cable
Re: MIDI over usb or midi cable
Why not do this:
Code: Select all
Triggers -> eDRUMin USB MIDI -> Drum Laptop
         -> eDRUMin MIDI Din OUT -> M-Audio MIDISport IN -> DAW Laptop
Polyphonics
Post by Polyphonics »
Rob wrote:Why not do this:
Code: Select all
I have some other MIDI events going on in the laptop that I need to send across so makes sense to funnel them into one cable.
That's probably something OP ought to do with a MIDI merger though.
OftheSeven
Post by OftheSeven »
Code: Select all
This was/is my original idea that I will test once I authorize SD3 for the Drum laptop.
I assume this suggestion has the lowest latency since the source midi is going directly to the corresponding computers.
Some may have seen this post on Vdrums about MIDI DIN vs MIDI USB:https://bit.ly/373GxGT
There may be a 1ms or so difference using the DIN cables.
In the same thread - some doubt the reliability using 4-eDRUMIN units at the same time.
