Hi,kristerbluegenes wrote:Hi I'm new to all of this and have a basic question that i have not found on the forum:
- What do we choose when selecting "pad type" for Hi hat. There is no Hi hat "pad type"....i've tried dual zone and, no matter what i choose, i can't get a sound from the hi hat. I can get sound from everything except the hi hat. ANy help would be appreciated. Thanks.
Did you read the manual? And which VST do you use?
My guess is that you did not map the notes correctly. Generally speaking, you have to assign the notes in the pedal editor correctly AND assign the notes for the pad
- that you *choose* to be your hihat* - correctly. Which exact notes you need to assign for your pedal and for your designated hihat-pad depends on your VST.
Best regards,
Pim
*The pad type you select is irrelevant for this. You can use a 'mesh center piezo' to be your hihat. Or a 'Yamaha-3-Zone' pad. Or a 'rubber pad'. All of the pad types can be everything. All of them can make hihat sounds. Or Bass drum sounds. Or snare sounds. What sound they produce is determinded by the notes you assign.
