Seeking Advice on a Beginner's Kit
nemo
Re: Seeking Advice on a Beginner's Kit
Post by nemo »
If you want to avoid hotspot and keep positional sensing go for ATV AD-S13 as mentioned here by Rob:
viewtopic.php?f=29&t=1925&p=13174&hilit ... ice#p13174
nemo
Post by nemo »
... same about PD-120 - no hotspot.
Mstrchf
Post by Mstrchf »
nemo wrote:
Mon Feb 19, 2024 3:31 pm
They do hotspot unfortunately, I used a PD-120 as a snare for a few years. I would not recommend them as a snare as the rim detection is not on par with the PD-125 or newer. Edge sensor is on a single cross bar so the rim detection has some blind spots.
Edrumin 10 - UA Volt 276 - Macbook Pro 2013 - EZDrummer3 -
Roland VH-10 HiHat - CY-14 Crash x2 - Lemon 18" Ride - A2E Remo Bravo - Drone Halo Triggers -
14" Snare DrumTec 3ply - 10" 14" 2ply 22" SpareDrum 2ply - KDB-200
nemo
Post by nemo »
I have one because Rob developed ps it in the last releases of firmware.
Please click the link in my post above and read the Rob's post.
He developed it for those two. And in my opinion the feature is a gamechanger. That's probably the reason why Rob called it 'his snare of choice'
nemo
Post by nemo »
Mstrchf wrote:
Mon Feb 19, 2024 4:42 pm
Pads have to have a center mounted piezo for positional sensing
Not true anymore, fortunately 🙂
Mstrchf
Post by Mstrchf »
nemo wrote:
Mon Feb 19, 2024 4:46 pm
Apologies Nemo, you are 100% correct. I'll correct my posts so i'm not spreading bad information :D
I didn't realise that was possible. Tempted to get one myself!
