VersaTrigger and DWe triggers turn themselves on. As soon as a note is played on one of the pads it wakes up the hub.
Audio Front Wireless Triggers
Re: Audio Front Wireless Triggers
Ok, thanks. I saw the on/off switch in the manual and on pictures thus my mistake.
I even wondered if Rob would do a Kickstarter or something to find it?
I'm just shooting random thoughts out lol
The technology exists to accomplish it I just don't unless how hard it would be to get functioning.
If I was DW or Roland I'd be selling a wireless triggers system set. They'd make a fortune. And could tap into the entire electronic drums industry not just the wealthy few
Versatrigger were amazing. I had no latency issues at all. I had 3 sets of these I absolutely loved them. I sold them because there were not any updates for the interface, which in fact was similar to the EDRUMin. Very easy to use and very inexpensive. I remember them being around $45 USD. I only had issues when they had to add some type of midiox program online with windows10 then it became a bit clunky to me. But they worked perfectly!
I had a set of versatriggers too, they worked great with my roland pads, I got real rimshots when hitting head+rim at the same time, no latency, but kept waiting for cymbal triggers, I emailed Paul back and forth and he kept pushing their release so in the end I sold them too because I needed a roland module anyway for the cymbals.
They had input boxes you could plug in to for cymbals. They had 3 zone support. I used them with my stealth cymbals and Yamaha hats, PCY 135 and 155 flawlessly. Instead of a trigger it was a 35mm cable that went to the trigger box to a 1/4 trs into the cymbal pad. I wish they were never sold to DW. But I am happy for Paul.lalo wrote: ↑Wed Feb 07, 2024 1:24 pmI had a set of versatriggers too, they worked great with my roland pads, I got real rimshots when hitting head+rim at the same time, no latency, but kept waiting for cymbal triggers, I emailed Paul back and forth and he kept pushing their release so in the end I sold them too because I needed a roland module anyway for the cymbals.
Really? I don't even remember, it was a long time ago, 10 years ago maybe.
Just giving this a bump in hopes that Rob may have a comment
