eDRUMin version 2.3 BETA
Re: eDRUMin version 2.3 BETA
Changes in build 2
  • Fixed a firmware bug preventing the iOS app from working properly.
  • Fixed an issue with turning on velocity curves.
  • Improved the hihat position stabilization when using a hihat stand with very loose tension.
  • Fixed hihat position CC not always being sent on the correct channel.
  • Highpass filter control no longer hidden behind other controls.
Stereo Anthony
Post by Stereo Anthony »
Amazing! Thank you Rob!
I've just spent the weekend fine tuning all my drum kits and wanted to start looking into buy a new snare drum that will support positional sensing and my EDrumin10. Currently I have all Yamaha pads from a DTX 700 kit.
Aside from the DDT MS-140 I saw in your video, what else will work?
I'm looking at the Roland PD-140DS and the Drumtec Pro 3 snare drum.
Any others I've missed?
Stereo Anthony
mprinz wrote:
Sun May 28, 2023 8:13 pm
Do you know the Jobeky stuff?
https://jobekydrums.co.uk/product-categ ... y-e-drums/
I know of them, so I'll have to have a look.
AKA Wayne
Post by AKA Wayne »
Does the bell input on a 3 zone ride need to be on the ring only? My bell that is wired to tip is no longer working with this version.
Yes, it needs to be on the ring and afaik it has always been that way.
AKA Wayne
Post by AKA Wayne »
Ok. Thanks. I know I switched it to tip when I had it on a splitter. I took it off the splitter and thought it was working before updating to this new version but I must have been wrong. Thanks for that confirmation. I can stop chasing other issues.
Luckymethod
Post by Luckymethod »
On Mac if you're using a non-admin account none of the presets are visible. It's a bit of a pain cause I have a non privileged user set up for my son for his practice and he can't switch presets when going from practicing with melodics to practicing with ez drummer.
I can provide more info if necessary.
AKA Wayne
Post by AKA Wayne »
I think this has been asked but I forgot. Would it be possible to include a separate velocity curve for snare articulations, or scalars?
Seperate velocity curves for different articulations has been around for quite some time already. You just need to make sure your device is in advanced mode.
