using 6 or more midi expression at same time
BrunoGabirro
Post by BrunoGabirro »
Dear Robert,
I am thinking to buy 6 midi expression units and I have just a couple of questions at the moment:
1. When I go to the "buy now" button in the midi expression page it use allows me to buy one unit. Do I have to repeat this procedure 6 times, one for each unit I want to buy?
2. I plan to use them all at the same time with 6 Yamaha FC 3 Sustain pedals. This pedal has a continuous response, will the midi expression pass this continuous information?, since a lot of sustain pedals are just on/off.
3. Can I use 6 midi expression devices at the same time?
Thank you very much,
Bruno Gabirro
Re: using 6 or more midi expression at same time
The answers to all your questions are yes--with one crevete that the Control Application can only configure 4 devices at a time. However, once configured, you can use them all at the same time.
