Using Midi expression
ptbuzzcut
Post by ptbuzzcut »
I just saw this little device and thought it might be a solution. I am using Hauptwerk Virtual Pipe Organ. I need an expression pedal the is USB or midi to the software to recognize it. I also see I can use a TSR to convert a volume pedal to an expression pedal. After doing this, if I use this 'adapter' will it convert the 'expression' pedal to midi data on a CC channel?
Is the device configurable if I need to change what the Virtual Software sees in case there is a multiple assignment? Really hoping this will be the solution.
Re: Using Midi expression
The answers are yes and yes. While I've never tested MIDI Expression using an analog volume pedal, some posts online about using a volume pedal as an expression pedal using a special TRS-> DUAL TS cable seem to indicate it will work. I'll try to get my hands on one and test it for myself.
Reagrds,
Here's a relevant link. It seems that this sort of setup should work just fine.
http://www.strymon.net/2011/10/10/strym ... ion-pedal/
gwillimw
Post by gwillimw »
hi Robert - would you mind contacting me? i'd like to ask something in private about your your new interfaces.
thanks
