PC
http://www.audiofront.net/ME_Control_PC_2.8.3.5.zip
macOS
http://www.audiofront.net/ME_Control_OSX_2.8.3.5.zip
A BETA version of the iOS app is also available via the TestFlight app. Use this link to get access.
https://testflight.apple.com/join/L9hNy4CX
Improvements
- Much improved and calibrated pedal sensing performance for all generations of MIDI Expression devices.
- Improved stability of the Control Application for all operating systems.
- When calibrating a pedal, the auto-select feature is suspended.
- Fixed an issue where the UI would not load completely until an input was selected.
- In iOS touching the background of the firmware section will no longer toggle controls underneath.
- Disconnecting a device will now be properly reflected in the iOS Control Application.
- Due to an iOS CoreMIDI bug, the iOS Control Application can become unresponsive when unplugging and replugging in a device. If the UI doesn't update a couple of seconds after you plug in the device, unplug it and try again.
- The very first generation of MIDI Expression devices sold before July 2015 will have pedal sensing issues with a Yamaha FC7, which isn't properly supported by that generation of MIDI Expression. I have some extra second generation Quattros kicking around which I would be happy to donate to customers with first generation devices. Send an email to support at audiofront dot net.
Changes in build 5
- Improved the pedal calibration process.
- Fixed a notarization issue with the macOS installer.
- Fixed issues when using an expression pedal as a sustain.
- Bug fixes
- Fine tuning for Yamaha FC3A
