Midi Expression with Zoom FP02M
min
Post by min »
Hi all
Just wondering how the midi expression works with Zoom FP02M? Is the Zoom a passive expression pedal that goes straight into the midi expression which connects to USB input on computer? Or does anyone know if the Zoom pedal requires power? Does the MIDI expression (single one) need a powered expression pedal or can it work with passive pedals?
Re: Midi Expression with Zoom FP02M
That pedal will work fine with a MIDI Expression. As far as I know, all expression pedals are passive devices.
min
Post by min »
Great to hear. Does this mean the zoom pedal has the correct polarity? Does this mean the pedal will work with the midi expression adapter via USB no external power needed? Can anyone inform if optional USB cable is USB 2 or USB c?
MIDI Expression inputs are auto polarity reversing, so no concerns there. There no need for external power. As explained on the purchase page, it takes a USB 2.0 type B cable.
