Hello.
Is it possible to program the pedal to do program change +/- from the current program?
But I also will be changing programs from other device. Can the pedal also do +/- program change reflecting any program change I have made from another device?
So basically, if I am on Program 100, click pedal, goes to 101 (or 99 for the double click).
Thanks!
Program Change +/-
Re: Program Change +/-
If the other device is routing its MIDI out to the MIDI Expression, it will update its values accordingly.
