I bought a M-Audio SP-Triple that I can't use with my keyboard as there's only a single sustain input. Is the Midi Expression Quattro compatible with this pedal?
Thanks
M-Audio SP-Triple compatibility
Re: M-Audio SP-Triple compatibilty
Yup. That pedal will work fine with the Quattro or the iO.
Thanks Rob, I'll order it straight away thenRob wrote:Yup. That pedal will work fine with the Quattro or the iO.
