Hey, first time posting.
Is it possible to connect two foot switches (Boss 5U's) to one port? If so, do they send separate cc's? Also, when using note mode can I long press the pedal to send continuous msgs as long as the pedal is momentary? I'm trying to trigger pads/synths in Ableton using midi notes and long press for sustained notes.
Looking forward to your answers,
Thanks!
2 questions:
Re: 2 questions:
Yes, you can. Check the FAW about connecting two mono footswitches. And yes, they can be configured independently of each other.yoabro wrote:Is it possible to connect two foot switches (Boss 5U's) to one port? If so, do they send separate cc's?
I'm not totally clear what your question is here. When using a footswitch in 'note mode' (asumming the pedal is momentary), the pedal functions in the same way as a key on a keyboard. When you press the pedal down, the NoteOn message is sent, and when you release the pedal, the noteOff message is sent. I hope that clears things up.yoabro wrote:Also, when using note mode can I long press the pedal to send continuous msgs as long as the pedal is momentary?
