I am having some problems with my MIDI expression (single input version).
MIDI expression control prompted me to update the firmware, but crashed when doing so.
Here is the latest crash log:
2015-11-06.17:03:52 -------Starting Firmware Update--------
2015-11-06.17:03:52 OS: OSX
2015-11-06.17:03:52 Using standalone version...
2015-11-06.17:03:52 Firmware 1.0.0.0
2015-11-06.17:03:52 Latest Firmware: 2.2.1.0
2015-11-06.17:03:52 Reading firmware file: /Users/Henry/.AudioFront/ME/.hex
2015-11-06.17:03:52 ERROR: Error reading hex file: /Users/Henry/.AudioFront/ME/.hex
2015-11-06.17:48:25 -------Starting Firmware Update--------
2015-11-06.17:48:25 OS: OSX
2015-11-06.17:48:25 Using standalone version...
2015-11-06.17:48:25 Firmware 1.0.0.0
2015-11-06.17:48:25 Latest Firmware: 2.2.1.0
2015-11-06.17:48:25 Reading firmware file: /Users/Henry/.AudioFront/ME/.hex
2015-11-06.17:48:25 ERROR: Error reading hex file: /Users/Henry/.AudioFront/ME/.hex
(I've had the same problem on two different machines with the same device).
Any help would be greatly appreciated, I'm going to be needing to use the MIDI Expression a lot over the next couple of months.
Thanks in advance,
Henry
Firmware Update Problems
Re: Firmware Update Problems
Hi Henry,
That looks like it's probably the crash log from the second machine. If you have the first crash log, I'd like to get a copy of that as well. At any rate, the fix is to update the firmware using the instructions in the following thread. Sorry for the troubles and let me know how it goes.
http://www.audiofront.net/forum/viewtop ... f=26&t=185
Hi Rob, thanks for your reply.
Just tried running the manual firmware update, here is the result:
Last login: Fri Nov 6 18:30:29 on console
HenryBunettsMBP:~ Henry$ /Users/Henry/Downloads/ME_Firmware_OSX/UPDATE_FIRMWARE.command ; exit;
Current Path:
--- MIDI Expression Firmware Update ---
What color of device do you want to update?
(r)ed
(b)lue
(g)reen
(y)ellow
(w)hite
blac(k)
Press the letter of your choice and [ENTER]: k
Opening Teensy Loader...
Unable find Teensy Loader. Is the Teensy Loader application running?
logout
Saving session...
...copying shared history...
...saving history...truncating history files...
...completed.
[Process completed]
Also, here's the crash log from the first machine that I attempted the auto update on:
2015-11-06.16:44:46 -------Starting Firmware Update--------
2015-11-06.16:44:46 Firmware 2.0.0.3
2015-11-06.16:44:46 Reading firmware file: /Users/Henry/.AudioFront/ME/BLACK.hex
2015-11-06.16:44:46 ERROR: Error reading hex file: /Users/Henry/.AudioFront/ME/BLACK.hex
2015-11-06.16:48:25 -------Starting Firmware Update--------
2015-11-06.16:48:25 OS: OSX
2015-11-06.16:48:25 Using standalone version...
2015-11-06.16:48:25 Firmware 2.0.0.3
2015-11-06.16:48:25 Latest Firmware: 2.2.1.0
2015-11-06.16:48:25 Reading firmware file: /Users/Henry/.AudioFront/ME/BLACK.hex
2015-11-06.16:48:25 No legacy reboot device found
2015-11-06.16:48:25 Sending DSPC reboot command
2015-11-06.16:48:26 Closing ME device
2015-11-06.16:48:26 Found Halfkay Device.
2015-11-06.16:48:26 Reading firmware file: /Users/Henry/.AudioFront/ME/BLACK.hex
2015-11-06.16:48:26 Programming teensy...
2015-11-06.16:48:27 ERROR: error writing to Teensy
2015-11-06.16:54:01 -------Starting Firmware Update--------
2015-11-06.16:54:01 OS: OSX
2015-11-06.16:54:01 Using standalone version...
2015-11-06.16:54:01 Firmware 1.0.0.0
2015-11-06.16:54:01 Latest Firmware: 2.2.1.0
2015-11-06.16:54:01 Reading firmware file: /Users/Henry/.AudioFront/ME/.hex
2015-11-06.16:54:01 ERROR: Error reading hex file: /Users/Henry/.AudioFront/ME/.hex
Thanks,
Henry
Current Path:
(r)ed
(b)lue
(g)reen
(y)ellow
(w)hite
blac(k)
logout
Saving session...
...completed.
[Process completed]
Thanks,
Henry
Thanks for that first crash log. To get the firmware to install you might need to command-click to open that teensy application before you run the script. OSX security settings will prevent the script from opening the teensy application automatically.
Success!! Rob, thanks so much for your help.
Henry
Henry
Having a similar problem with the Quatro-sent a support request but have not yet received a reply-updated the control app on my 21014 Mbp OS 10.10.3-got the "need to update firmware" and did so from the tab on the app before downloading the separate firmware files.
After it failed I downloaded the firmware files and followed the above instructions-no go-and now the Quatro no longer functions at all-any suggestions would be greatly appreciated.....thanks-Roger B.
Hi Roger,
I got your support request. I'll get back to you shortly.
