Help! When will Midi Expression be back in stock?
twaw001
Post by twaw001 »
Hi, I really want to get this and check it out, but it's been out of stock for a while. Can you please tell me when it will be available? I don't have a use for the Quattro, I only need the Expression... I plan to use it with a standard sustain pedal to send CC21 with about a 60 or 70 value, to Kontakt 4 free Player running the Sax Brothers, in Cantabile 2.0.0.2049 VST host ("solo performer" version), Windows 7 x64. I read the manual and it sounds like it should work well, but please advise if you foresee an issue. If it works I'll be psyched because I can then use the "growl" sax function with a really small footswitch that fits in my gig bag easily!
I really need a solution quickly, so any info on when it can be shipped will be appreciated... thanks!
Tom
Re: Help! When will Midi Expression be back in stock?
Thanks for the heads up--I'm just getting back from vacation. Forgot to update the inventory level. It's listed back in stock.
twaw001
Post by twaw001 »
Awesome, thanks
