new firmware sysex question
avixx
Post by avixx »
hi :)
new here.
i’m looking to translate expression pedals into variable data byte sysex messages and am simply wondering if the new firmware allows this.
thanks!
Re: new firmware sysex question
No, currently the SysEx messages are static. Can you describe your use case though so I can consider implementing it in the future?
avixx
Post by avixx »
sure!
it’s simple really, i’m just looking to, using my feet on expression pedals, modify parameters in real time on a synthesizer (roland hand sonic) that are only accessible by sysex (and not by cc).
thanks!
phil
Thanks. I'll consider it for the next version. What kind of value range do you think would be required?
